Loosing clutch pedal, 00' 6 speed - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-22-2008, 10:10 PM Thread Starter
AFBLUE's Avatar
The past couple of days the clutch pedal has been getting worse. earlier today it was going to about 1/2 inche from floor before it will let me shift into get, and by tonight I have to shut the truck off to get it into reverse. Its not to the point I have totally lost it, where I cant get it out of gear, or be able to stop but I fear its on its way there. The clutch systems seems pretty simple, it just bothers me its all plastic. Is there any ideas, air in the system?the res is full. How would you bleed it?
AFBLUE is offline
post #2 of 11 Old 05-22-2008, 10:34 PM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
I have been told easiest to bleed it on the bench but if you need a new one i have a spare i can send for a reasonable price.
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #3 of 11 Old 05-23-2008, 08:39 AM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
probably the slave or master cylinder going.. Even being plastic it holds up pretty well. and the new "kit" is really simple to install. hardest part is getting the old rod off the clutch pedal.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #4 of 11 Old 05-23-2008, 05:15 PM Thread Starter
AFBLUE's Avatar
New master cylinder from NAPA was 59.00 going to replace and bleed per instructions and see if that solves it.
AFBLUE is offline
post #5 of 11 Old 05-23-2008, 05:20 PM
smitty16s's Avatar
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
does anyone know where to get a good aftermarket clutch? one for the 450hp range?
1999 F-250 Supercab 6spd 2WD
Custom tunes by Tony Wildman,
AFE stage 2 Intake, ZooDad Mod, 2 Guages, Grand Rock 5" Aussie Stacks, Train Horn Qssb Quick Spool WOP, ITP regulated Return, Boost Regulator, Pioneer avic d3 Coming Soon: Injectors,short throw shifter, southbend clutch
smitty16s is offline
post #6 of 11 Old 05-23-2008, 05:52 PM
scheidt27's Avatar
i think Raul at Stealth who is a sponsor on here sells clutches. id talk to him
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
post #7 of 11 Old 05-23-2008, 07:11 PM
Cj Ford's Avatar
yup... South Bend Clutch
About South Bend Clutch
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #8 of 11 Old 05-23-2008, 07:32 PM
Quoted: 5 Post(s)
to SouthBend!
John Wayne
REDNECK VALDEZ
You can find me on
post #9 of 11 Old 05-23-2008, 07:37 PM
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
for the Southbend!!!
Got mine from Patrick at Discount Power Parts. CONFE is the ONLY way to go....(Unless you have a TON of $$$....then get the twin disk!!!)
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #10 of 11 Old 05-23-2008, 07:47 PM
smitty16s's Avatar
thanks guys
