Transmission Crossmember/Mount?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-27-2013, 06:06 AM Thread Starter
Nemo's Avatar
I have 01 F250 4x4 4R100
Does anyone know who sells crossmembers to lower the rear of the transmission?
ProComp does for '08+ however the won't work.
Thank you in advance
Nemo is offline
post #2 of 10 Old 08-27-2013, 06:10 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Are you talking about the one the carrier bearing sits on?
2000-7.3L is offline
post #3 of 10 Old 08-27-2013, 06:41 AM Thread Starter
Nemo's Avatar
Negative, it's what the rear transmission mount sits on.
The stock one looks like this but less FUBAR:
http://i.ebayimg.com/00/s/MTE5NVgxNjAw/$(KGrHqR,!j!FBuH5eh,3BQrZfZn0H!~~60_1.JPG?set_id=8 80000500F
Nemo is offline
post #4 of 10 Old 08-27-2013, 06:42 AM
2000-7.3L's Avatar
link no worky
post #5 of 10 Old 08-27-2013, 06:53 AM Thread Starter
Nemo's Avatar
Nemo is offline
post #6 of 10 Old 08-27-2013, 06:53 AM
2000-7.3L's Avatar
I can order you a new one!
post #7 of 10 Old 08-27-2013, 07:04 AM Thread Starter
Nemo's Avatar
imgur: the simple image sharer
This is an image of mine
The previously posted one was just an example of what it was.
My truck has an 8in lift
I do not need a replacement OEM one. I'm looking for crossmember with a drop of roughly 3in to reduce the drive angle from my transfer case.
Nemo is offline
post #8 of 10 Old 08-27-2013, 07:15 AM Thread Starter
Nemo's Avatar
One Up Offroad Cross-Member Drop Kit - 1999-2010 F250/F350 4wd - Driveline Accessories
I found this, just don't like the price.
May end up fabricating my own..
Nemo is offline
post #9 of 10 Old 08-27-2013, 07:17 AM
2000-7.3L's Avatar
Why not just weld drop brackets to it?
post #10 of 10 Old 08-27-2013, 08:00 AM Thread Starter
Nemo's Avatar
Just doing that would interfere with the front driveshaft
So I would have to cut, bend, add another piece that comes up and over it
Unless I make a whole new one in a similar design or in a tubular design
Nemo is offline
