Trannie problems after chip install - Ford Powerstroke Diesel Forum
Old 05-18-2008, 11:34 AM
I just installed new stage 2 injectors and a TW 6 pos chip. I took it for a test drive and my truck does not want to shift from 1st to 2nd. I pulled the chip and it will shift but only after you bring it up to 2100rpm then decelerate, it will then shift smoothly. It will not shift under acceleration. 2nd-3rd is fine and so is OD. I put a scanner on it and have NO codes. It does not feel like it is slipping but simply will not shift. Could the new power have damaged the trannie this quickly, I had no issues before. Seems like a sensor but not having any codes concerns me. I will call DP in the am but was hoping someone has an idea. Due to my most recent mods I am broke. bad time for the trannie to go. really hoping it is not that bad. Thank you in advance
Old 05-18-2008, 11:36 AM
heres a bump. hope you get it worked out!
