should I flush it? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 08-21-2013, 05:04 AM Thread Starter
should I flush it?
I have a 2002 f250 with the 7.3 and auto transmission. The truck overheated a few times before I could figure out the problem. I know when the engine overheats you should change the trans fluid. I've been told to get it flushed then I've also been told to just drop the pan since the truck has 202,XXX miles. I bought the truck when it had 170,000 miles on it and I'm not sure when/if the previous owners changed the fluid. The fluid definitely doesn't smell fresh now however. Any of you guys have an opinion on this?
TXdieselpusher is offline
post #2 of 20 Old 08-21-2013, 05:13 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
the most i would change is drain the pan drop it change filter put back on and refill no more if at all.
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #3 of 20 Old 08-21-2013, 05:18 AM Thread Starter
Are flushes really that bad for a high mileage transmission? I thought the purpose of a flush is to help out higher mileage ones. Thanks for the reply by the way.
post #4 of 20 Old 08-21-2013, 08:07 AM
Quoted: 727 Post(s)
Yes. And no.
Corey@CNCFAB is online now
post #5 of 20 Old 08-21-2013, 10:24 AM
CSIPSD's Avatar
I'm confused as to why you would change the Trans oil if the motor overheats?
Your fine to change all the fluid, its easy and does not hurt anything.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 20 Old 08-21-2013, 12:14 PM Thread Starter
Because of the trans lines going into the radiator. There is a trans cooler in the bottom of the rad right? I'm still new to this truck and honestly I don't know much about it.
post #7 of 20 Old 08-21-2013, 12:26 PM
CSIPSD's Avatar
If the motor overheats... fix the motor.
Don't change the trans fluid because the motor overheated...
I would figure out why the motor overheated? That NEVER happens on a 7.3 unless there are significant issues.
Joe
CSIPSD is offline
post #8 of 20 Old 08-21-2013, 12:39 PM Thread Starter
The overheating problem is fixed now. I thought the fan clutch was bad since I never heard the fan come on when it got hot, so I changed it. Still overheated. So then I went to the next easiest solution, the thermostat. It hasn't overheated since. The only reason I want to change the trans fluid is because I was told if the engine overheats then the trans fluid overheats too since it flows through the radiator. Is that not true?
post #9 of 20 Old 08-21-2013, 01:25 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If you have a combined cooler, your trans could've gotten hot, but who knows how hot.
Doesn't hurt to get in new fluid at all.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 20 Old 08-22-2013, 05:30 PM Thread Starter
So yesterday I dropped the pan, changed the fluid, and filter. It seemed to shift better and seemed to be working fine. Then today (99 degrees in the shade here in Texas) the engine started overheating again after more then a week of running fine. So it seems like I have more work to do. Thanks for everyone's input on my original question, it's hard to find anyone knowledgeable on these trucks at the local part stores.
