tranny going???? - Ford Powerstroke Diesel Forum
Old 05-17-2008, 07:02 PM
Send a message via AIM to cowboymafia
tranny going????
the over drive light is flashing and its shifting funky i just put the ts on yesterday and its already attacking up when it goes to shift into 2nd and 3rd but fine in the rest of the gears and thats one the 140 setting and when i put it back to stock it does the same thing but not as bad... any thing would help mods are listed below not much over stock
Old 05-17-2008, 07:06 PM
Feedback Score: 4 reviews
Your computer isn't seeing the correct voltage it should, have the pcm scanned and you will come up with some codes to get you started.
Old 05-17-2008, 07:23 PM
Also, keep in mind that the 97 has a funk shifting pattern any way.
I didn't notice mine until I put a chip in, then it is magnified when I'm turned all the way up.
Tony is going to correct it as soon as I send it back in.
Oh and my PCM code is TDE1 which is what most 97's have.
