p0743???
got the p0743 code today.... i was searching around and everyone else who had this also got a p0741 code. maybe my scanner didnt pull that one
?What to do now. f81z-7g391-cb is the part number needed right? is this just something i am going to have to go into ford for? |
bump........
nobody......????
with this code the truck has been really rough. stumbling, a lot of change in the rpms. wont idle properly. but it does this intermittently, it is not everytime i drive or all the time whne driving. also the torque converter wont lock up.
so i know this code would cause the torque converter problems but are the other symptoms common to this or do i have another problem along with it? |
P0743 Torque Converter Clutch System Electrical Failure
P0741 Torque Converter Clutch Circuit Performance/Stuck Off There are 2 different issues. I would consult a trans shop. |
ok thanks. that is what i am going to do. i am taking it back to the trans shop that just did the work on it, they said they would get it all figured out.
Good deal.
do you happen to know about the symtoms i have discribed above?
Sounds like your converter is trying to lock up at idle, I don't know really. I'm not a transmission guy.. so.. I don't know. The issues you listed above could be a lot of things, but you would have other codes.
alright good to know. i will see what happens after the transmission shop is done and go from there.
