pan leaking? - Ford Powerstroke Diesel Forum
Old 05-13-2008, 05:58 PM
pan leaking?
does the pan gasket go bad? my trans was serviced not to long a go, just noticed after towing my car, there is a puddle under the truck, looks like its coming from the pan, hard to tell
Old 05-13-2008, 06:12 PM
ADMIN AND TECH
the pan gasket doesnt go bad , and isnt a gasket at all but is special silicone made just for that application, very seldom see one leak, and if it does leak, generally doesnt leave a puddle , is usually just a seep to very slight leak, more than likely if you have a puddle under the truck, need to look on top of the engine in the valley its proably wet in there and running down, there is a hole in the back that allows the oil to run out the back of the engine and drips on the ground between the trans and the engine
Old 05-13-2008, 06:32 PM
its def trans fluid, still red, not sure how long its been leaking, just noticed it, its been parked for about 2 weeks
Old 05-13-2008, 06:36 PM
ADMIN AND TECH
sorry i thought you meant oil leak from oil pan, if you just noticed the leak oly after towing a car , then that would be the front seal in the trans , front pump seals are fairly commo to leak , especially after towing or during towing , the trans gets hot and pukes fluid out the front, probably newd to get seal replaced , may even want to add an extra trans cooler
