Click when shifting into park - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-26-2013, 10:50 PM Thread Starter
usteffenhagen's Avatar
A lot of the time these days when I shift into park from drive, sometimes reverse, I will hear this "click" immediately after shifting. I heard this a few weeks ago and found one of my U Joint strap bolts snapped. Got that taken care of and now this click is back. I checked all the other bolts and everything is good. any ideas what the problem is or are there any checks I can do to try and narrow it down?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 7 Old 07-27-2013, 09:30 PM Thread Starter
anyone???
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #3 of 7 Old 07-27-2013, 09:36 PM
Quoted: 728 Post(s)
It may be a hairline crack in the drive shaft itself.
Corey@CNCFAB is online now
post #4 of 7 Old 07-27-2013, 09:38 PM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
Have you checked your front flange bolts?
See this:
I found the bolt missing from the bottom hole on my driveway. Ended up putting Lock-Tite them and re-torqueing them.
I suggest, at least, looking at them to see if the two surfaces are slipping.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 7 Old 07-28-2013, 03:42 PM Thread Starter
See this:
Checked out the bolts they're good and I can't find any cracks that I can see
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 7 Old 07-28-2013, 03:44 PM
05_PSD_Erik's Avatar
That broken U-Joint bilt could have allowed the U-joint to have some play in it and caused the needle bearings inside the U-Joint to fail. I would start with new u-joints as they are fairly easy to change and somewhat cheap. As compared to a new driveshaft or something...
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #7 of 7 Old 07-28-2013, 04:17 PM Thread Starter
I did that u joint when I was extracting the snapped bolt. Could it have affected the other u joints? I can't feel any vibrations while driving
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
