4r100 issue after putting in 1st gear - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-23-2013, 06:16 PM Thread Starter
bigpanther2004's Avatar
Had a buddy that was moving his boat from one lake to another and when he wento pull out from unloading the boat he put his truck in 1st gear and nothing would happen.He tried putting it in everyother gear and nothing would happen,put it in reverse and reverse works fine!!! Did some testing with a pressure gauge and the gauge just sits and spikes all over the place. Pulled the pan nothing out of the abnormal in the pan changed out the solenoid pack and when he started the truck it reved up so he shut it down then started it back up had no throttle at all so he messed with the TPS wires and it got working ( unless the TPS is just somthing that happened to be going bad). Trying to explain to him that we need to pull the tranny and see what the insides look like but others are saying its electrical just seeing what everyone else thinks????
bigpanther2004 is offline
post #2 of 5 Old 07-23-2013, 07:28 PM
Quoted: 14 Post(s)
Any ODB codes?
ttyR2 is offline
post #3 of 5 Old 07-25-2013, 05:29 AM Thread Starter
There are no codes.
post #4 of 5 Old 07-25-2013, 05:38 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
either solinoid pack or it's time for a rebuild I'd check the connectors to make sure they all clean if they is then time to re-build
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is online now
post #5 of 5 Old 07-25-2013, 01:27 PM Thread Starter
The solenoid pack that he tried was a good one so that rules that I'm, were guessing either a sprag let loose or something alot those lines, but like I said he had other people saying its not a hard part cause it "just happend" they say its more electrical.
