Hard jerk when shifting (4R100) - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-19-2013, 02:23 PM Thread Starter
7 3 Powerstroke's Avatar
It's been doing it for a while, it was a slight jerk at first, but now it's horrible. I had an Edge Juice and thought that was the issue, but I uninstalled the chip and it still jerks bad. I read that a new valve body would fix most of this. What could be the cause of this? How can I fix it?
2001 7.3L F350 Crew Cab, Long Bed, Dually.
Modifications: aFe Stage 2 CAI, 4" Flowmaster Exhaust with 7" Tip, XDP Compressor Wheel, Foil Delete, Glowshift MaxTow Gauges (Boost, EGT, and Pyro), and Tony Wildman 6 Position Chip.
7 3 Powerstroke is offline
post #2 of 9 Old 07-19-2013, 02:34 PM
SMOKIN'POWERSTROKE's Avatar
Subscribed...
2002 7.3
107,000 Miles
Still in High School
|Zoo Dad mod| Soon to be Straight Piped| Diy Intake In Progress|
SMOKIN'POWERSTROKE is offline
post #3 of 9 Old 07-20-2013, 04:58 PM Thread Starter
Can anyone help?
post #4 of 9 Old 07-20-2013, 05:34 PM
Quoted: 822 Post(s)
Is this though all gears?
Corey@CNCFAB is offline
post #5 of 9 Old 07-20-2013, 10:04 PM Thread Starter
It was originally just shifting from 3rd to overdrive, but after the chip it's through all gears.
post #6 of 9 Old 07-21-2013, 04:55 AM
Quoted: 822 Post(s)
I'm not much of a transmission tech but by your description I was thinking a PO installed a shift kit. The Edge bumps the pressures a bit, but it still does it after removed. Are you getting any soft trans codes?
post #7 of 9 Old 07-21-2013, 05:54 AM Thread Starter
Not that I know of.
post #8 of 9 Old 07-21-2013, 11:57 AM
7.3550Duty's Avatar
That's what the edge tuner will do to your trans, that's why they burn up your trans after awhile. If it were me, I would sell that edge, and get some custom tunes on a ts style chip. A lot better for your truck and you will be alot happier with how your truck performs
Robert
01 F350 CCSB
a few mods
7.3550Duty is offline
post #9 of 9 Old 07-21-2013, 09:47 PM Thread Starter
Already done. Except I'm waiting on the custom chip.
