03 7.3 powerstroke transmission not engaging. HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-16-2013, 03:28 PM Thread Starter
Unhappy 03 7.3 powerstroke transmission not engaging. HELP!!!
Hi I have a 03 7.3 powerstroke with 97k on it. It had a superchip but it has been put back to stock.
The truck has been shifting odd (shifting in and out of gear and holding gears) so I parked it. I got back into it yesterday and the batteries were dead. I jumped it and put it in drive and it was perfect for about 7 mins. Then it started acting like it was falling out of gear. I pulled it over and turned it off. Restarted it and it shifted from first to second fine then did it again. So I pulled over and tried it again. I had nothing. Not drive 1st 2nd or reverse. It was like I was in neutral. I was able to get it home by feathering into the pedal.
The fluid is perfect with no burnt smell.
PLEASE HELP!
dougsoscia is offline
post #2 of 2 Old 07-17-2013, 10:24 AM
timmyboy76's Avatar
Check the linkage first. If good, then i say tranny or TC bad/going bad.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
