o/d switch/ tc lock up - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-14-2013, 05:37 PM Thread Starter
new power stroke owner. couple tranny questions/concerns. First off its a 99 7.3 and a auto. 4r100.
The o/d off switch doesn't work. push it, nothing happens and no lights come on. tranny shifts normal under any condition.
Second, (and new to these trucks so it may be nothing) but under normal acceleration this things seems to drop into overdrive real quick. at or just below 40mph and once its in there you got to really hammer that throttle to get it to kick down. is that normal on these trucks?
If I accelerate real hard it seems like its running through ALL the gears normal. Shifts real good no matter how I drive it, just seems like it drops into overdrive too quick unless I really hammer on it and once its in overdrive man you almost have to hold it wide open to get it to kick down.
brokenframe is offline
post #2 of 5 Old 07-14-2013, 05:51 PM Thread Starter
oh ya, and is it normal for this thing to decelerate so hard? if its going faster then 45mph and I let off the throttle it coasts for a second then kicks down like a engine brake and decelerates pretty hard. I've just purchased the truck and it has around 240k on it. The tranny was rebuilt around 180k. Is this all normal operation for this truck or should I investigate more?
post #3 of 5 Old 07-14-2013, 09:32 PM
700xxmaniac's Avatar
Seams Perty normal to me! I'd cheak the wires to the od switch
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #4 of 5 Old 07-14-2013, 10:01 PM
Absolutely normal transmission wise. I suspect your o/d button is out or the wiring to it at least. These 4r100's really, really hang on to the gear unless you hit a steep grade, or smack down on the throttle for a bit. It at least tries to accelerate before it drops the gear down.
'01 7.3L PSD SCLB
Rubber:Ballistic Jester 18x9, 325/65/18 Falken Wildpeak A/T's << LOVE THEM!!
Motor:CCV mod, Zoodad mod, Edge Evolution CTS, Coolant Filter, Cat ELC, Dual Optima Yellowtop Batteries, 6697 mod
Suspension: Polyurethane sway bar link kit, 6" lift
Naterenfo1 is offline
post #5 of 5 Old 07-15-2013, 05:22 AM Thread Starter
Thanks guys, I appreciate the feed back. I'll just drive her then. I started another thread in engine trouble about engine clatter. Check it out if you have time. I would really appreciate feed back on that since I know there is something wrong there.
