7.3L 4r100 tranny cooling - Ford Powerstroke Diesel Forum
post #1 of 27 Old 06-26-2013, 04:28 PM Thread Starter
kentuckypowerstroke03's Avatar
Alright, I know the 4r100 is crap. but the 7.3 is great. my tranny is running into the 190 area unloaded on a hot day. Just had tranny rebuilt and is still getting hot. 1. should I just go ahead and buy a 6.0 cooler? or 2. should I buy this
BD-Power Xtruded Auxiliary Trans Cooler 1300601-5.5
:flag
2003 F250 4x4 Super Duty 7.3L
4x4
95,000 miles
4R100
CTS gauges
6.0 Transmission cooler
Shift kit
K&N cold air intake
Straight pipes
PLENTY LEFT TO DO!!
kentuckypowerstroke03 is offline
post #2 of 27 Old 06-26-2013, 06:30 PM
russtwentyfour's Avatar
I bought this cooler, http://www.summitracing.com/parts/der-13504/overview/
And this pan, http://www.summitracing.com/parts/der-14208/overview/
I rarely see over 150 unloaded, and have hit 185 once while heavy towing in traffic. This is all in 95 plus temps high humidity. Also I installed the cooler inline with the old cooler.
Hope this helps.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 27 Old 06-26-2013, 09:38 PM
7.3550Duty's Avatar
look into doing the bypass valve delete really helps with cooling on these trannys to. buddy did that along with 6.0l cooler and rarely sees 190 pulling his 15k hauler around
Robert
01 F350 CCSB
a few mods
7.3550Duty is offline
post #4 of 27 Old 06-27-2013, 04:52 AM
How much more fluid did the pan and cooler add to a stock setup?
zillafreak is offline
post #5 of 27 Old 06-28-2013, 04:59 AM
merc123's Avatar
http://www.dieselsite.com/specialord...ioncooler.aspx
Proven set up. Been over 150* with a 9k load only a few times but never seen over 170 and that is usually on mountain roads where I'm doing 30 MPH with hardly any air flow.
'00 F350
Mods: Nitto Trail Grapplers, Diamo 17 Karat wheels, Red-head Steering box, Autometer gauges, Tru-Cool #4739 trans cooler, BFxenon HID lights
'03 Mustang GT
Mods: A bunch. -->
merc123 is offline
post #6 of 27 Old 06-28-2013, 06:44 PM Thread Starter
Thanks guys. I went ahead a put a 6.0 cooler on and it dropped around thirty degrees. I really like the bigger tranny pan, going to pick one up soon. Thanks
:flag
4x4
95,000 miles
4R100
CTS gauges
Shift kit
K&N cold air intake
Straight pipes
PLENTY LEFT TO DO!!
post #7 of 27 Old 06-28-2013, 08:53 PM
Pan added about a gallon of capacity, when I filled mine up it took a little over 4 gallons. Keep in mind I added pan, cooler and dieselsite filter system at same time, but did not change torque converter fluid. Hope this all helps as it has helped mine tremendously without breaking my wallet.
Mbrp 4" turbo back
Ww2
Afe rear end cover
post #8 of 27 Old 06-30-2013, 06:43 PM Thread Starter
I was wondering if a feller could put bigger transmission lines from the trans to the cooler. That should help to? I know the stock lines on the 4r100 are really small, maybe quarter inch or so. Maybe enlarge them to half inch or five eights. What do you all think?
:flag
4x4
95,000 miles
4R100
CTS gauges
Shift kit
K&N cold air intake
Straight pipes
PLENTY LEFT TO DO!!
post #9 of 27 Old 06-30-2013, 06:56 PM
jesilvas's Avatar
Quoted: 2 Post(s)
What were you doing making your trans get to 190*F?
I run about 150*F-165*F unloaded hwy cruising, and about 185*F with a 9k lb fifth wheel.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 27 Old 06-30-2013, 07:43 PM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
mine runs 180+ unloaded normal driving with 85% highway. i have a 6.0 cooler and just did a new oem bypass tube. fluid was flushed 30k ago and temps have been this way ever since I have owned the truck. what few times I tow, it gets into the 220+ range. any ideas?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
