Increasing trans temps - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-25-2013, 11:40 AM Thread Starter
merc123's Avatar
I've had a temp gauge for a while now and a tru-kool trans cooler inline with the factory.
Normally, unloaded and in 70-80* weather I'm about 125*. Loaded it might get to 150* or if it's above 90* it'll get to 150-165 (loaded or unloaded).
Lately I've been noticing that in some of the cooler 70 and 80* weather my temps have started to stay in the 150 range, unloaded. I was wondering if this is a sign of anything going wrong or am I being paranoid?
Fluid is still clean and nearly "invisible" on the dispstick and only has about 50k miles on it. Doesn't smell burned at all.
'00 F350
Mods: Nitto Trail Grapplers, Diamo 17 Karat wheels, Red-head Steering box, Autometer gauges, Tru-Cool #4739 trans cooler, BFxenon HID lights
'03 Mustang GT
Mods: A bunch. -->
merc123 is offline
post #2 of 11 Old 06-28-2013, 08:58 PM
russtwentyfour's Avatar
Read somewhere on this forum about bypass line sticking open causing trans to bypass around cooler. I would pull return line off the cooler and see if getting good flow, maybe flush system just to be safe. Also I believe and I could be wrong but the trans fluid interval is like 30k. Maybe a trans guru will chime and and add more to what I've said.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 11 Old 06-29-2013, 10:28 AM
bigpanther2004's Avatar
do the cooloer bypass its real simple
bigpanther2004 is offline
post #4 of 11 Old 09-03-2013, 10:39 PM
blue72's Avatar
Feedback Score: 5 reviews
What is the cooler bypass?
2000 F350 XLT SCLB 4x4
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
Stewart Warner Gauges
blue72 is offline
post #5 of 11 Old 09-04-2013, 02:03 PM
One the passenger side of the trans there is a tube that connects the two line, you take it out and put in block offs, this makes all the fluid run through the cooler, if ur interested I have a set I'll sell you, get on xdp or ats and look them up they have a little more info on them.
post #6 of 11 Old 09-04-2013, 03:24 PM
Macon's Avatar
I think it would be better to put a manual valve in there. That way you don't have "too cool" of an issue in cold climates.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #7 of 11 Old 09-04-2013, 04:54 PM
blue72's Avatar
So it is a bypass delete, gotcha, thanks.
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
blue72 is offline
post #8 of 11 Old 09-04-2013, 04:57 PM
Raul@Stealth Automotive's Avatar
wait your worried about a 150 degree temp in your trans fluid? if so do not worry... that is perfectly normal.... i wouldnt start to worry until you reach over 200 degrees....
Raul@Stealth Automotive is offline
post #9 of 11 Old 10-28-2013, 11:49 AM Thread Starter
merc123's Avatar
I fixed it. Flushed the fluid out. Back down to 125*. 150 when towing.
'00 F350
'03 Mustang GT
Mods: A bunch. -->
merc123 is offline
post #10 of 11 Old 10-28-2013, 07:17 PM
Vannnce's Avatar
Quoted: 13 Post(s)
curious what fluid you run
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
