how much fluid will i lose? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-22-2013, 01:52 PM Thread Starter
Quoted: 16 Post(s)
Feedback Score: 3 reviews
i need to change the bypass valve. i put a 6.0 cooler on and it's still 180 with the outside temp of 92, this is with a empty truck. how much fluid will i lose?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #2 of 4 Old 06-22-2013, 02:34 PM
ZMANN's Avatar
Quoted: 1456 Post(s)
your high enough I can't imagine it would be much ?
but no first hand knowledge
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 06-22-2013, 03:23 PM Thread Starter
Quoted: 16 Post(s)
i didn't think there would be any because when i did the cooler there was nothing in it(i assume that it drains back to the pan), but when i went to take the bypass loose it starting leaking. just trying to see how much fluid i need to get.
post #4 of 4 Old 06-22-2013, 08:24 PM
JSchuricht's Avatar
When I did mine a few years ago, it was just a continuous trickle, mostly from what was in the lines. If you bought a quart, you should still have some left over when your done.
JSchuricht is offline
