Picking the right Clutch! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-20-2013, 05:52 PM Thread Starter
car94's Avatar
Smile Picking the right Clutch!
Clutch Choice F-450
I have a 2000 Ford F-450,7.3 liter, 2WD, It has a Luk button style ceramic clutch that is about 5 years old with 84,000 miles on the clutch. The Throw out bearing is starting to go. I want to replace the the whole assembly. The truck is a Bucket truck that Idles more than it drives and also weighs 14,990 lbs before equipment and tools and the XR 650 are loaded. So most of the times I have weighed the truck it scales around 16,500 lbs. So I am wondering what the best clutch for a constantly heavy load would be?
I am still trying to figure out if the stock Clutch was 11" or 13" and if the replacement has to be the same size. Or can I go up to a 13" inch without replacing the flywheel?
I sent it off to a transmission shop to have the original clutch replaced and do not know if the Luk was a 11" or 13".
car94 is offline
post #2 of 2 Old 06-20-2013, 10:46 PM
timmyboy76's Avatar
13". There's threads going around, where the pilot bearing is upgraded, using the 6.0 bearing.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
