Transmission problems. Torque convertor ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-19-2013, 06:34 PM Thread Starter
Today I was pulling trailer down the road speeds of 45 to 55.
I was watching my tranny temp slowly rise all the way to 220 degrees I then pulled over and let it cool.
I started traveling again and my overdrive light started flashing I read the codes and I got PO741 - (TCC System Performance Torque Converter Slip Greater Than Expected).
So what does this mean ? I need a new torque convertor ?
It was slipping because of tranny temps ?
Why was the transmission getting so hot?
Thanks for the help!
Zach
Transmission problems. Torque convertor ?-imageuploadedbyag-free1371695691.763365.jpg
2002 F-350 7.3 ex-cab short bed Beans 6 Pos
6 inch lift, 35,s, 4 Inch Turbo Back, 6637 intake
Foil delete, 05 harley front end, 08 Tailights
Tinted cab lights, and this and that and this
Z-STROKE is offline
post #2 of 7 Old 06-19-2013, 06:40 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Could have been getting hot due to unlocked TC, which only you can answer if it was or not.
Maybe the bypass is stuck and not putting fluid to the cooler.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 7 Old 06-19-2013, 06:52 PM Thread Starter
TC was not locking like it should ..
Z-STROKE is offline
post #4 of 7 Old 06-20-2013, 06:28 AM Thread Starter
Why wouldn't my torque convertor be locking ? .. ****ty tunes ?
Z-STROKE is offline
post #5 of 7 Old 06-20-2013, 12:58 PM
JSchuricht's Avatar
Your code indicates that it was trying to lock but couldn't. That could be anything from a weak pump, clogged line, too much power, tired TC or even a bad tune. Most likely something is giving out in your transmission. Start saving your pennies.
JSchuricht is offline
post #6 of 7 Old 06-20-2013, 01:09 PM Thread Starter
How can I find out what the problem is and get it fixed
I can't afford to have this keep overheating and having to stop on the road to let it cool
Z-STROKE is offline
post #7 of 7 Old 06-20-2013, 01:11 PM
JSchuricht's Avatar
Take it to a trans shop and have them pull everything apart to inspect it.
