One Minute Good, next, not so much. Bent Fork? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-19-2013, 07:33 AM Thread Starter
Quoted: 2 Post(s)
2001 ZF6 with 83000 on it - only has a hypertech (I know, I know) but other than that, is stock.
truck shifted great coming home from work - but an hour later, fired it up, shifted into first and just didn't feel right - thought it must be in my head so I made a note of it.
Came to first stop, very spongy feel to clutch, but it went into first, I slipped it and off I went to the next stop - clutch in, shifter in first, brake on - engine lugging a bit - light turns green, I let off the brake, and the truck starts creeping forward and the clutch will not come off the floor. I pull it out of gear, and basically let it go down-hill to the house, where I had to urn it off, put it in gear, then use the starter to get it into the driveway - the clutch will still not come off the floor, and I have to yank it out of gear if under load.
I suspect 1 of three things (or maybe 2 or all 3, who know yet) and want your thoughts.
1) Bent clutch fork - would explain all the symptoms - and probably not dependent on mileage, but in truth, the age of my truck my be a bigger problem.
2) Master/Slave cylinders - no signs of leakage though, and seem to be working - I suspect these are still good.
3) Clutch itself is broken - or some other internal part like the throwout bearing or pressure plate.
Okay masters of the heavy metal - place your votes and rationalize them.
Thanks!
01 F350 Dually 4x2 Long 7.3 - Manual - Mods: Hutch, Harpoon, Remote Fuel Filter, Southbend Clutch, Heim Joint, Gauges, Disabler, 08 Tail w/Camera, Pioneer Head w/Lockpick, Exhaust Brake, Rails, Air Raid, 06 Headlights, 50 cent. Coming next: Exhaust. Wish list: Train horn, 4x4 conversion, Exhaust, Turbo, Chip.
06 Mustang GT - GCC spec (Infidels May be closer than they appear)
16 Sonata Hybrid - Gas saver
Arizona_SVO is offline
post #2 of 3 Old 06-20-2013, 10:52 PM
timmyboy76's Avatar
with 83k, i'd just replace the master/slave assy with a pre-bled system..(on my 3rd one, 170k.
Remove the slave and measure the distance from it, to the outer hole of the tranny. If more than i think 2-3/4in, its bent...
Name:	clutchfork measure.jpeg
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 3 Old 07-12-2013, 05:18 PM
I think that it will be done if you would be spend at least 50k and make the nice solution to replace the master assy with the pre bled system.
Brady1121 is offline
