Buzzing after shut down - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-17-2013, 06:36 PM Thread Starter
atgreene's Avatar
Hey guys!
I did a transmission fluid change, (only did the pan capacity, did not flush the lines).
Ever since i did the fluid change, (DEX/MEC), after shutting off the truck, i hear this loud buzzing noise coming from the trans pan.
it shifts fine and trans temp is not hot.
Sounds electrical, like a solenoid or something within the transmission.
doesnt make the noise while running, only when shutting off for about 20 seconds then goes away.
Thanks for the help!
atgreene is offline
post #2 of 6 Old 06-20-2013, 07:09 PM Thread Starter
atgreene's Avatar
anyone? i really dont want to find out its smoking my trans
atgreene is offline
post #3 of 6 Old 06-20-2013, 07:35 PM
usteffenhagen's Avatar
I'm not sure but did you try google'n it already?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #4 of 6 Old 06-20-2013, 08:23 PM Thread Starter
atgreene's Avatar
i have tried. and havent found anything similar.
atgreene is offline
post #5 of 6 Old 06-20-2013, 08:54 PM
If you put your hand to the trans pan can you feel the buzz?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 6 Old 06-20-2013, 09:02 PM
It could be the line pressure control solonoid going out.. I'm not to knowledgeable of this so I'm not sure if there is a fuse or what for it.... Wish I could be more help..
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
