35" Tires Can Ruin My Tranny? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-13-2013, 10:46 PM Thread Starter
Post 35" Tires Can Ruin My Tranny?
Hi, pretty new here, and one week into ownership of a '01 F350 CC 4x4 PSD with 173,000 mi. I scour the internet for maint/repair vids to help me save money, and I've found some great videos on YouTube. A particular PSD mechanic in GA, has many helpful videos, and from what I can tell, he knows his business, but to my question: He claims that running big tires w/o re-gearing will ruin your transmission, and also shorten the life of the hub bearings on a 4x4. I am running a 4" lift with 35x12.50R16.5, All-Terrain T/A KO. Are these considered over-sized tires, and should I be concerned that they will wear my equipment out prematurely even if I service it properly? Much obliged for any thoughts.
RafterQ is offline
post #2 of 7 Old 06-13-2013, 10:57 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
You are fine... nothing to worry about
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #3 of 7 Old 06-13-2013, 10:59 PM
TheFordman87's Avatar
I would say 35's will put a little more strain on the tranny and your brakes. But you shouldn't have anything to worry about. It also really depends on how you drive it and if you tow real heavy loads. But I wouldn't be really concerned about all of that unless you go up to 37's or bigger.
So in a nut shell you should be fine and have nothing to worry about.
I'm addicted to diesel and I step on it constantly!
TheFordman87 is offline
post #4 of 7 Old 06-13-2013, 11:06 PM Thread Starter
Not pulling heavy loads, and I drive all my rigs pretty easy...hot-rodding stayed behind with my youth
Thanks for the replies, I feel easier about it already!
RafterQ is offline
post #5 of 7 Old 06-13-2013, 11:10 PM
You should have no worries for sure then
post #6 of 7 Old 06-14-2013, 12:05 AM
BIG Laing's Avatar
The weakest point of the good old 7.3's was/is the tranny. If you drive it like a bat out of hell all the time, and tow more then you should, your tranny life will be shortened. And that is shortened even more with larger diameter tires, as you are adding more stress.
From the stock 32ish tires, to 35's isn't that big of a jump though... So IMO treat your truck right, and you will be fine.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #7 of 7 Old 06-14-2013, 01:33 PM Thread Starter
obliged!!
RafterQ is offline
