Need transfer advice - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-12-2013, 09:27 PM Thread Starter
I have the 4r100 and the od originally went out but I continued driving in drive for a couple months and the the truck finally stopped going fwd and had to get it towed. I rebuilt it and replaced the overdrive planetary and new gaskets. I got it back in the truck and filled up with fluid. It went in reverse and went backwards, then went into 1st and moved fwd. 2nd and drive didn't get the truck moving? If I take it out of overdrive the drunk would want to go fwd. and at idle would move a lil bit.??? Any suggestions?? I also can't start it by turning the key I have to go and jump then relay to get it started but when I tried the first time the key was successful?? Any ideas?
Hondamxr is offline
