Tuner temp vs. dash gauge temp - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-31-2013, 10:34 PM Thread Starter
I have a 2003 7.3 pulling empty the tuner gauge reads up to 254 deg the dash gauge will read in the center and sometimes move up but never into the yellow or red any opinions what is going on would be appreciated.the tuner is an edge.
Joshed not is offline
post #2 of 7 Old 05-31-2013, 11:28 PM
JSchuricht's Avatar
The gauge on the dash is basically a idiot light. Once it moves to the hot position it's too late. I can't say how accurate the Edge is but if it's even close your probably going to need a new trans soon.
JSchuricht is offline
post #3 of 7 Old 06-01-2013, 05:50 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Here's an interesting article on that subject -> dieselmann's editorial
NoRalPh is offline
post #4 of 7 Old 06-01-2013, 03:34 PM Thread Starter
Thanks for the link lets me know the stock gauge's normal operating temp is wide. Any info on what would be causing the high temps. Like I said truck is empty. I want to pull a trailer this summer... The reason I purchased the truck . Any help appreciated.
post #5 of 7 Old 06-01-2013, 11:51 PM
JSchuricht's Avatar
The stock cooler is really small but you still shouldn't be anywhere near those temps. You could flush the trans and check the flow at the same time but I suspect something is slipping to create that much heat. How many miles are on it?
post #6 of 7 Old 06-02-2013, 08:39 AM Thread Starter
The truck has 160,000 on it. The trans was serviced about 6000 miles ago. Doesn't seem like any slippage is happening when. driving.
post #7 of 7 Old 06-02-2013, 11:57 PM
JSchuricht's Avatar
You can't always feel the slipping, it doesn't take much to create heat. If you have a scanner you can check the slippage of the TC but even then it could be a internal clutch.
