Puzzling 4r100 issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-21-2013, 07:13 PM Thread Starter
Hi, I am no stranger to rebuilding transmissions, but this one has me stumped. Rebuilt the trans using suncoast parts, triple disc, and upgraded snap ring on forward drum, problem surfaced about a 1000 miles into it. No codes, but sometimes no forward gears, always have reverse, works most of the time, but happens when trans is warm. My deduction has been a seal that's seeping or sticking boost valve, but seems to me with a sticking boost valve reverse also wouldn't work. When it finally does work, it still has all gears like nothing is wrong Haven't hooked up a trans pressure gauge yet as it works fine when it does. Sorry for the long post, but wanted everyone to get the picture. Thanks.
gfaststroker is offline
post #2 of 3 Old 01-10-2014, 05:38 PM
Did you ever find the problem, I have the same issue with my 01, been in the shop seven times still not fixed.
Thanks!
Rodney Weaver
352-622-4992
rweaver is offline
post #3 of 3 Old 10-09-2016, 05:05 PM
Have you figured out what the problem was? i have an 01 and i lose all forward gears only after backing up with a trailer attached. i have to coddle the throttle and start out in 1st then work my way through 2nd and into D. been in shop twice but no answers.
dutchdirtman is offline
