4R100 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-21-2013, 07:31 AM Thread Starter
4R100
My transmission was under water during Super Storm Sandy. I let everything dry out, I cleaned the two electrical connectors, did a whole transmission flush and installed a 6.0 transmission cooler. Ever since then when I start my truck my overdrive light blinks until I start to drive, then it goes away. Also my transmission hits 180 degrees rather quickly. And once it hits 160 degrees it starts to slip at high RPM's, when I get around 2200 RPM's they shoot up and I loose all acceleration. Once I let off the gas it shifts. My fluid is still red but smells a little burnt. Could it be a bad torque converted or is my transmission toast? And did I do something I shouldn't have? There was quite a bit of salt water that came out of the transmission. Thanks for any input.
2001 f250 cc sb, Zf6 swap with zoom 650 horsepower clutch, Ts six position chip, Banks 4" turbo back exhaust, Ats ported compressor housing, riffraff high flow compressor wheel, riffraff boost fooler, 10 inch lift on 40 inch procomps xtreme terrains, RiffRaff FRx, Airraid cold air intake, boost and egt gauges.
Mario_SD is offline
post #2 of 2 Old 05-22-2013, 12:09 AM
JSchuricht's Avatar
I would plan on getting it rebuilt. Odds are something is corroded or the clutches are swelling/comming apart and some seals are toast. You could pull the codes to see what the blinking OD light is trying to tell you but I would still plan on a rebuild reguardless.
JSchuricht is offline
