Rebuilt tranny- does a triple disk converter overheat in traffic - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-15-2013, 11:38 AM Thread Starter
Had my transmission rebuilt. Bts valve body new seal, heavy duty clutch packs, and a triple disk converter. Truck is a 2000 quad. Cab dually. My fiancÚ was driving it home and it stayed at around 160 highway but as soon as there was traffic the temp was hitting 180 to 190. Tranny temp sensor is in the transmission drivers side. Is this normal under normal driving conditions on a 65 degree day? The shop told me it was and that they recommend a 6.0 cooler.
Cheap, Fast, Reliable...pick two
2000 F350 dually 4 door for more wh**es
Mbrp 4"
Riff raff HPX and FPX
Riff Raff 6337 MOD
BTS Valve body
Rosewood 160/100's
Beans tunes!
Gauges , EGT, BOOST, oil temp, oil press, fo press,trans temp.
jackinggear is offline
post #2 of 4 Old 05-20-2013, 01:18 AM Thread Starter
Nothing???
Mbrp 4"
Riff Raff 6337 MOD
BTS Valve body
Rosewood 160/100's
Beans tunes!
post #3 of 4 Old 05-20-2013, 03:47 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
With the increase in clutch surface, and the higher pressures from the valve body, and the little tranny cooler, sounds about right.
The 6.0 cooler is the cat's meow for the 7.3 trans. Put one on and there should be no issues at all.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #4 of 4 Old 05-20-2013, 03:49 AM
Term3's Avatar
To me that's a little high unless there's a lot hills and she's holding the truck in traffic with the transmission instead of the brakes. Putting in a 6.0 should be at the top of your to-do-soon list.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
