need some guidance - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-12-2013, 04:30 PM Thread Starter
risnerry's Avatar
need some guidance
i picked up a 99 powerstroke the other day and it had a tranny problem. when i start it up theres like roaring sound towards the front of the transmission. and the truck wont even budge. i have the axle out of it and when its running in any gear i put it in the output shaft is still spinning. and i can stop it with my hand. even when i give it throttle... while the truck is running when i go to put it in park it grinds, but if i shut it off and put it in park and start it up it runs fine and i can shift it out of it.
any ideas what it could be. or ideas where to start looking into, i planned on pullin the trans anyways just need ideas of a starting point. or if you think the trans is completely toast? and my trans is auto so thats the 4r100 correct?
risnerry is offline
post #2 of 3 Old 05-13-2013, 08:14 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Any codes?
Miles?
Doesn't sound good...
If you end up needing a new trans and are keeping your truck a BTS is the last trans you will buy.
PM if we can help.
CT Performance, Inc. is offline
post #3 of 3 Old 05-13-2013, 10:23 AM
timmyboy76's Avatar
sounds also your flexplate is cracked. Make sure the shift linkage at trans is not sloppy too.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
