kennys double disk slipping help! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-07-2013, 04:57 PM Thread Starter
hammerstroker's Avatar
all my mods are in the sig. went to pull out in front of someone today and all it did was slip while i was tryin to get on it. it drives fine with a little fuel but when i stomp it, it just slips. this clutch is rated for up to 600. oh this clutch maybe has 15,000 miles. anyone got any info thanks
"BIG RIG" auto to zf6 swap 00 f-350 cclb dually,4in rough country lift, 6637, 7in mitre stacks, wicked wheel, foil delete,live tuned from bill at php,triple pod autometer gauges,315/75r16 kelly tsr's, 05 front end conversion, 2in spacers for rear,stage one swamps 175cc single shots,boost fooler, kennys dual disk clutch.
hammerstroker is offline
post #2 of 8 Old 05-08-2013, 05:00 PM Thread Starter
tried calling him today and nothing. and im not buying another clutch. im not spending 1200 bucks on something that last 15,000 miles. might go back to auto if i can find someone to swap for a built auto. i maybe push 350hp and im slipping it??? horsecrap
post #3 of 8 Old 05-08-2013, 05:19 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
That sucks man.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 8 Old 05-08-2013, 05:24 PM
Njstroker91's Avatar
What material is the clutch? Full ceramic?
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #5 of 8 Old 05-08-2013, 05:26 PM Thread Starter
sure is. its just really annoying. if i could find the right truck i would just trade this truck. pref a non dually. its like one thing after another
post #6 of 8 Old 05-08-2013, 05:30 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Sell that one, buy a 6.0 and bring it to me to bulletproof for you! J/P.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 8 Old 05-08-2013, 05:30 PM
I would Attempt to get ahold of them and see maybe they will cut you a deal on a new one since 15000 seems pretty low. Pop the inspection cover off the trans and get a flashlight and see if the material looks really worn out on the clutch pac.
post #8 of 8 Old 05-08-2013, 05:45 PM
Macon's Avatar
You're not leaking oil onto it are you?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
