O/D issues and superchips...Connected? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-05-2013, 03:26 PM Thread Starter
ThomasvillePavers's Avatar
Saturday evening on my way home from a trip I noticed a 6.0 with LOADS of "diesel performance" style logo's all over and a tiny stock exhaust with a tip so I decided to play around and romp on the ole' truck and let him hear some spooling action then 2 blocks down I proceeded to the interstate on ramp and he got his justice... My truck wouldn't shift into O/D and then after it hit around 60mph it starting slipping bad and I had to slow to 45mph, so I limped it 1 mile to the next exit and got off. Checked all the normal stuff, trans temp was good, trans fluid level good and looked/smelled fine so I took some back roads I knew the rest of the way home and when accelerating the first 3 gears seemed to shift normal but would take 1-2 minutes cruising at 50mph+ and then slowly shift into O/D but never felt the TC locked so I flipped my TC lockup switch and nothing happened.
Got a chance to look the truck over today and all still seemed o.k. so in preparation to take her to the trans shop tomorrow I thought about the superchips and seeing some prior threads of issues I decided to unplug it and drive it today and there are NO issues... Of course the shifts are different than before but feel like factory and now even the TC lockup switch is working again!
The superchips is the style that plugs directly into the PCM case and has a small 2 wire switch (I don't know which model but where it plugs in it's a small gold metal housing with the superchips name stamped on) do you think this little guy is related to any issues? I will still take the truck by the trans shop tomorrow and have it checked out and maybe go ahead and have it gone through, but I am curious!!
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #2 of 2 Old 05-09-2013, 03:18 AM Thread Starter
Update:
We got the truck back from the transmission shop with good news! there was a bad connection to the trans wiring harness and with new fluid and filter and the wiring fixed we are back on the road, first day back we hauled our heaviest load to the job site with no issues... The load is a steel wheeled roller and LeeBoy paving machine with trailer over 38,000lbs.
Total repairs:
Fluid and filter $212
Wiring $56
And BTW the Superchips is still in and keeping the shifts nice and firm!!!
-Brad
