02 tranny fluid pouring out - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-02-2013, 04:56 PM Thread Starter
Got home from work and found a river in my driveway. Crawled under the X and found tranny fluid all over the underside. I have an ISSPRO tranny gauge and was running 160 degrees all day.
Vehicle is a 2002 excursion 7.3 4wd with 118k. Never towed much of anything. I serviced the tranny around 3k miles ago and changed the filter and installed aftermarket valve body. Truck is stock, no chip.
First picture is where it is leaking from, right at the mating surface. Second picture is my driveway after 10 seconds of waiting for garage door to go up.
Thoughts? Is this a common issue? Will the tranmission need to come out to diagnose?
I've never pulled a tranny or driveline before. I've pulled a turbo, installed and egr delete kit on a cummins, installed lift kits, but never a tranny. With the right tools is this a job I should even consider taking on?
w74bronco is offline
post #2 of 2 Old 05-02-2013, 05:27 PM
Macon's Avatar
The only thing there is the flywheel and torque converter. I would venture your torque converter crapped out, or your front seal gave up. You can definitely pull it if you desire. Nothing a jack, jack stands, and a few wrenches can't do.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
