think my tc just took a crap. am I rite? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-17-2013, 04:23 PM Thread Starter
Hi everyone. So I was heading home from work yesterday and I started having problems after it would shift. It would shift and run through first and second fine but after shifting into third while accelarating it seems it not grabbing once I hit like 1600 or so rpm.but if I power through it, it will shift again and do the same thing. That's why I think its the tc. I'm no expert on trannys so advice would be great. Also if it is the tc can I replace just that or is there other stuff I need to replace with it.
If it is the tc should I not drive it at the risk of hurting the trans or doesn't it matter?
Thanks again.
early 99 F-350 cc, lb, 4x4
tony wildmann 6 pos.
4 in turbo back to a pair of 6" black chrome miter cuts
foil delete, stage 3 cold air intake
6 in lift with 37"s
238/100 sticks
not much but its a start
gibbogr is offline
post #2 of 4 Old 04-17-2013, 05:05 PM
Macon's Avatar
To me, it sounds like your clutches are done. You're actually at the point I expect to be at next tire change, and that's time for a rebuild or upgrade. I'd rather upgrade. I'm not a tranny expert either, but I offer free advice all the time.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 4 Old 04-18-2013, 04:57 PM Thread Starter
Ya. That's what I was hoping ppl wernt gunna say. Haha. Looks like I might be giving bts a call.
6 in lift with 37"s
238/100 sticks
gibbogr is offline
post #4 of 4 Old 05-05-2013, 04:33 AM
Do it now. There was a month wait for mine. I went through stock trans and then two more stage three 500hp rebuilt pos before smartening up. Pay up now not more later, that is if you plan on towing and keeping the truck. I've seen. BTS trans go for $3000 used with 100k miles one them, they pulled it and threw a sticker in go sell the truck, not everyone could appreciate a BTS.
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
