tranny overheating while towing - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-17-2013, 01:34 PM Thread Starter
kentuckypowerstroke03's Avatar
I have an 03 f250 7.3 auto, just bought it about a month ago. 94,000 miles on it. the truck runs fine until I pull something and the temp gauge goes to the red, and you can smell it outside the truck. If anyone knows how to fix it, let me know. thanks
kentuckypowerstroke03 is offline
post #2 of 6 Old 04-17-2013, 02:08 PM
Quoted: 156 Post(s)
Feedback Score: 3 reviews
WOW, in the RED on our gauge it too late, the fluid is shot for sure, hope not the trans too
dieselmann's editorial
Verify the cooler and bypass are functioning first, but it could just be that the frictions are slipping when loaded and overheating because they're worn-out...
NoRalPh is offline
post #3 of 6 Old 04-17-2013, 02:14 PM Thread Starter
Well, this happened about a week ago, and still driving fine and shifting good. I wonder if I should have the whole system flushed out and install new fluid?
post #4 of 6 Old 04-17-2013, 02:22 PM
SuperCrutyPS's Avatar
Quoted: 310 Post(s)
Garage
If you have the stock tranny cooler, consider going to a 6.0L cooler. See the difference (6.0L on top):
One of the best things I did to my truck! Pulling my 12K 5er, I could easily peg my gauge going up grades in the summer. After the new cooler, it gets warm, but nowhere near pegged.
If you do that, blow out the lines to make sure they are clear. You could also check to see if you have an inline tranny fluid filter. It might be clogged or getting that way. Any idea on how long the fluid has been in there? Maybe time for a fluid change.
Just some ideas.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 6 Old 04-17-2013, 02:29 PM Thread Starter
Well, I bought an after market cooler, but haven't installed it yet. Its about the size of the 6.0. I don't know much about the truck, I just bought it and it has 94,000 miles. When it got hot, it went to the yellow mark. I hope this didn't hurt the tranny! I am going the change the fluid soon. Thanks!
post #6 of 6 Old 04-17-2013, 05:09 PM
Macon's Avatar
After I bought the truck I dropped it off at the dealer and had them go over it good and solid like. While doing that I also had them flush the tranny. Flushes are good. After that was done, I dropped the pan, put in a different valve body and changed the internal filter as well. Even the dealer said not to worry about the filter. I smiled and nodded, and changed it anyway, because it's a filter. They filter, which means they get clogged over time.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
