Tranny Upgrade Help, IDK what im doing... - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-23-2013, 10:55 AM Thread Starter
Well here, Ill just pose my base question. I am getting a free rebuild under warranty from my builder. He will completely rebuild it replacing all the broken or worn parts with new stock ones for free. I want to upgrade some of these parts however and have about $1500 to do so (this includes the TC). So I want to find the best combination of parts and a TC for my application that will be under that $1500. I use my truck for a daily driver, and I want it to last. But i also want to take it to the track a couple times to see what she can do. I want a transmission that will hold up to 400-500 hp for many miles.
Wow that sounded really demanding haha. Iv made a parts list with a bunch of stuff. I know alot of the options overlap and what not but here is a list with prices and links to each part. Hopefully you guys (who are awesome btw) can help me decide what I do and dont need.
Input Shaft-$150-300
Ford 4R100 Transmission Input Shaft Billet 300M Hardened Steel | eBay
or
John Wood Automotive - Products
Intermediate Shaft- $50
Valve Body-$250
or
BTS valve Body
or
https://racerxusa.com/product_info.p...919f87f994d3b3
Spiral Snap Ring- $15
E4OD 4R100 Overdrive Spiral Snap Ring Sonnax 36744 01 | eBay
ZPAK- $120
E4OD 4R100 Zpak Intermediate Raybestos Z Pak 1989 On | eBay
Direct Powerpack-$100
E4OD C6 4R100 Alto Red Eagle Direct Powerpack 1966 On | eBay
Intermediate Powerpack
E4OD 4R100 Alto Red Eagle Intermediate Powerpack 89 On | eBay
Coast Clutch Powerpack that works with Cast Iron Coast Drum
E4OD 4R100 Alto Red Eagle Coast Powerpack 89 99 | eBay
Torque Converter $600-1000
4R100 Stage 4 Torque Converter
or
or
Stallion Torque Converters | Precision Industries
link>>> http://www.converter.com/images/stal...owerstroke.pdf
4R100 Precision Industries "Stallion" 3-Clutch Power Stroke Torque Converter :: FORD Stallion Torque Converters :: Pro-Built Automatics
Cast Iron Coast Drum w/ new planetary- $350 __From builder orů.
Sun Coast Diesel Transmissions*-*Ford 4R100 4 Disc Coast Clutch Drum | Catalog Products | Sun Coast Diesel Transmissions
Overdrive Powerpack- $75
E4OD 4R100 Alto Red Eagle Overdrive Powerpack 1989 97 | eBay
Front Hub to Forward Drum Washer-$5
C6 E4OD 4R100 Metal Front Hub to Forward Drum Washer | eBay
Possible complete kit, but need to see if he can make the kit for the Cast Iron Coast Drum Style- $500
4R100 Alto Red Eagle Kolene Friction Steel Kit 98 on with Powerpacks Heavy Duty | eBay
or
Sun Coast Diesel Transmissions*-*Ford 4R100 Xtreme Rebuild Kit 1999-2003 | Catalog Products | Sun Coast Diesel Transmissions
Do I want this? Bushing kit- $65
4R100 Ford Bushing Kit w Teflon Tail Bushing 1998 On | eBay
Do I want this? Overdrive Sprag Assembly- $100
E4OD Updated 2nd Design Overdrive Sprag Assembly 89 On | eBay
Do I want this? Boost Valve and Sleeve Kit-$40
E4OD 4R100 New Boost Valve Sleeve Kit by Sonnax | eBay
Steel OD Planet Kit-$100
E4OD 4R100 Ford Lincoln Steel OD Planet Kit | eBay
Center Support Kit-$90
E4OD 4R100 New Updated Bearing Type Center Support Kit | eBay
Servo Piston-$13
E4OD 4R100 Updated National Band Servo Piston New | eBay
Solenoid Pack-$240
Ford 4R100 98 2005 Solenoid Pack E4OD Transmission Electronics Powerstroke Only | eBay
Dual Load Center Support-$230
Sun Coast Diesel Transmissions*-*Ford 4R100 Dual Load Center Support 1989-1997 | Catalog Products | Sun Coast Diesel Transmissions
Line Mod Valve-$32
Sun Coast Diesel Transmissions*-*Ford 4R100 .500 Line Mod Valve 1989-2003 | Catalog Products | Sun Coast Diesel Transmissions
Thanks so much for any help/suggestions.
Caeden 2003 F-350 CCSB Silver Series 4x4 w/ 2000 7.3PSD BRUCE
Van Turbo w/ WW and EBPV Delete, 5" Flo-Pro Straight-pipe, AIS/6637 Intake w/ Outerwears Cover, CCV Mod, 140 IDM, AIH Delete, Hutch Mod, Harpoon Mod, Pre-pump Fuel Filter, Zoodad Mod, 203* T-stat, Foil Delete, RiffRaff OCR, Marinco Mod, Banks Gauges, Diablosport Chip, Warn Hubs, 6.0 TransCooler w/ Derale T-stat, 6.0 CAC
caedo is offline
