standard tranny slight shifting issues. - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-17-2013, 06:26 PM Thread Starter
Well the clutch doesn't slip at all but when shifting into certain gears usually 2nd and reverse it will go about half way into gear then as im slowly letting out it will fall into gear the rest of the way. Also the clutch squeaks everytime I push it. Also with the squeak, when pushing in it feels a little grainy from the pedal its self.
---David---
2000 Single Cab, 2x4, ZF-6
DIY 6637 Intake
PHP 6 Position Chip
5 Inch Custom Exhaust
Banks Gauges (Boost, Pyro)
High Pressure Oil and Fuel Crossover Lines
16 Inch XD Addict Wheels W/ Nitto Highways
david1991 is offline
Tags
clutch , clutch squeak , ford , zf6
