banks dynafact sender - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-16-2013, 02:46 PM Thread Starter
preachermanhull's Avatar
Quoted: 3 Post(s)
as stated above. Got the egt, trans temp, and boost with pillar pod for $50. Problem is...no trans temp sender. You know how the junk yard boys do it....sell the engine and trans...cut what ever you can. I found an egt probe that will work and a universal boost gauge install kit. However, i can't seem to find what sender in need for the trans temp. I don't think banks offers a replacement and if they did it would be ridiculous. Here's the question...what type sender do i need? Will any 1/8 npt single connection sender work? Thanks Guys!
Psalm 34:6 "This poor man cried, and the Lord heard him, and saved him out of all his trouble."
94.5 psd, 310,000,
ts chip, homemade cai,
3in dp 5in exhaust, 265/75/16 tires,
glowshift gauges,
zf5, fpr shim, bench seat so my honey can get close! SOLD!
98.5 psd, 245,000, new a/t, banks gauges, 06 interior, 4 inch exhaust 5 inch tip, the truck is red
-Hosstyle Dieselz-
2004 F-250 6.0 4wd, auto...and get this, 356,000miles on og engine/trans! Stock for now...
preachermanhull is offline
post #2 of 2 Old 03-23-2013, 06:11 PM Thread Starter
Quoted: 3 Post(s)
alright...the egt and boost gauge are hooked up and working fine. I did order an auto meter trans sender for a short sweep gauge..its also hooked but on a short 30min run this evening the trans gauge never moved. Below is a pic of the gauge i have...is there a way to check the gauge?? Also, it was about 45 degrees when i did the run today..is it possible that the trans never got up to 140?? Help please..LOL!
heres the sender i ordered
Short Sweep Electric Temp. Gauge Sender (250, 300, and 340 deg.)
Product #
2258
1/8" NPT. Includes 3/8" NPT and 1/2" NPT adapter fittings. DIRECT REPLACEMENT FOR ALL CURRENT AUTO METER SHORT SWEEP ELECTRIC GAUGES. Not Compatible with Auto Gage products.
This sender only works with product built in 1995 and later. Pre-1995 short sweep electric gauges have a black mask hiding the pointer hub and require a sender #2254.
and before someone says it...lol...i ordered this because i couldn't find the banks sender without ordering the whole gauge kit.
94.5 psd, 310,000,
glowshift gauges,
-Hosstyle Dieselz-
