Does the 4R100 Pump in Park? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-14-2013, 09:11 AM Thread Starter
Quoted: 6 Post(s)
Hi Guys,
I've had a few E4OD's in F150's and Bronco's before and thankfully they've been good to me. I was younger and didn't really do a bunch of looking into the trans before I moved on.
My question is, with my 2002 4R100 does it pump fluid in park? Is there any gears where fluid is not pumped - Neutral/Reverse? I've searched and seem to be finding some conflicting information.
Reason I ask, I use the truck to primarily tow my 27' Fifth Wheel and to Plow snow in the winter. I had a Ram V10 that I knew did not pump while in Park, so anytime it idled I left it in Neutral with the ebrake on to allow it to cool down.
My plans are to run a Derale Pan and a Hayden Tranny cooler with electric fan as well. Thanks in advance!
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
post #2 of 5 Old 03-14-2013, 09:46 AM
It pumps in P and R and 1-4, not sure/never check N but I feel certain it does. At least my 02 did.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #3 of 5 Old 03-14-2013, 09:35 PM
It must pump in park and neutral as both those gears hold the #1 clutch pack. Anytime the engine is running the pump is running.
Greenman01 is offline
post #4 of 5 Old 03-19-2013, 03:55 PM Thread Starter
Quoted: 6 Post(s)
Good to know thank you both!
post #5 of 5 Old 04-11-2013, 04:20 PM
There are no clutch packs applied in neutral or park. And , yes, the pump is pumping if the eng is running, unless the pressure regulator valve is stuck open. But then, you couldn't drive it any where.
ipz2222 is offline
