School me on ZF6 maintenance - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-13-2013, 02:08 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Hey guys the weather is starting to warm up here so project time is starting, so you guys need to school me on 6-speed maintenance since most the threads i read are about auto maintenance not manual.
So tell me what works for you guys with 6-speeds. What fluid, intervals, processes, special tools needed, etc. Anything you might deem worthy of saying. Like alot of people im afraid of looking at my tranny wrong let alone screwing up something but thats because i have never done it. Once i do it once ill be fine but i dont tend to like to crash course with such an expensive thing.
Thanks guys
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 10 Old 03-24-2013, 01:00 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
bump guys any tips?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #3 of 10 Old 03-24-2013, 07:00 AM
timmyboy76's Avatar
really, pull the drainplug on the bottom. Let drain, then remove the same looking plug, in the middle of trans, on driv/side, and fill up from there to she spills over. I use MERCON V only. I feel the Amsoil syn crap, KILLED my trans/syncros. Also, depending on how many miles you got on her, may want to invest in a master/slave assy, because it seems when they let go, your in the middle of nowhere.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 10 Old 03-24-2013, 05:27 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
well i know how to change the fluid im not talking about that, i mean like dropping the tranny and rebuilding it/replacing parts
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 10 Old 03-31-2013, 11:01 AM
350 ONE TON's Avatar
Why are you looking to pull it apart? Anything wrong with it? As far as dripping it to do a clutch they are fairly easy, they are just very heavy
2003 F250 XLT 6Spd 4X4 ECLB 4" lift 4" turbo back duals, AFE Stage 2 XP, superchips flashpaq (gone soon I hope) GTP38R, Gutted EBPV
350 ONE TON is offline
post #6 of 10 Old 03-31-2013, 08:42 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
No but i just think i would be good to take it apart and maybe replacing the friction rings or whatever they are called i cant remember. and yes as for the clutch i might get an upgraded clutch.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 10 Old 03-31-2013, 10:05 PM
If it aint broke, don't fix it.
99' Powerstroke is offline
post #8 of 10 Old 04-01-2013, 07:40 AM
timmyboy76's Avatar
damn things' a biatch to re-align to the flywheel. If i have to drop her again, once out, i'm grinding the molded floorpan joints, so the trans dont hang up on them.
post #9 of 10 Old 04-01-2013, 07:55 AM
Bean's Avatar
Send a message via Skype™ to Bean
Hey Pat I have had mine out and the case off of it cause the place that rebuilt it didnt shim it right and the input shaft keep taking out the seal on the front I couldnt find a big enough press or puller to get the front bearing off to shim it the right way so I made two shims out of paint can lids and put between the bearing and case and that fixed it as far aspulling any of the other gears or anything out I didnt go that far but i need to now a buddy who drives truck over the road tried to power shift it and burnt my first gear syncro so if you want help with it if we have a wrench day this summer i can show you a few things
The work truck
01 F350 7.3 6 speed RC LB 4x4
Foil delete CCV mod AIH Delete
Custom Zoodad Ford Severe Service AIS
Wastegate unplugged
3.5" Straight piped
DiPricol Optix Gauges
TW 6 pos chip
Ranchhand Front Bumper
The Family (Car)
08 F350 CCSB 4x4 6.4
H&S Mini Max CCV mod
Coolant Filter and Green Coolant
and lots more to come
Facebook
Bean is offline
post #10 of 10 Old 04-01-2013, 07:59 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Sweet sounds good, yea hopefully we can get some G2Gs this spring and summer
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
