Transmission case is cracked - Ford Powerstroke Diesel Forum
post #1 of 22 Old 03-06-2013, 02:24 PM Thread Starter
jse51599's Avatar
Does anyone know if this is common, or just my bad luck? My truck has been making a vibration at 40 mph and then again at 70 mph and higher. I was thinking u joints at first. But, now I'm thinking the transmission was going out this whole time. Or is it possible that the vibe caused the transmission to break? Today when I was driving the truck, I felt a thump and then I only had the vibe at 40 mph not at 70 mph. The truck seemed to shift fine on the way home, so...... I dunno. Guess it's time to take out a transmission.....
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #2 of 22 Old 03-06-2013, 04:42 PM Thread Starter
jse51599's Avatar
Jim
jse51599 is offline
post #3 of 22 Old 03-07-2013, 09:06 PM Thread Starter
jse51599's Avatar
Anybody... anyone.... any ideas??? Bueller..... Bueller?!?
Jim
jse51599 is offline
post #4 of 22 Old 03-07-2013, 09:26 PM
1BADTON's Avatar
Jse have you checked your motor mounts? And or your rearend? Had a turbo 400 shater a case only because the motor twisted the frame on a 69 chevelle as it shifted. The driveline was too long and jamed into the tail housing stopping the rotation and boom. So with that info my theroy is with a firm shift or a broken mount it might have done it? My rig is 9200lbs and when I had JW build my tranny the shift was hard and has some what calmed down sime my DP install?
1BADTON
01,Lariat CCLB, 7.3L, 8" Donahoe on 37"s, John woods, ARBs, 4:88, Hansen's frt&rear, 15k Warn, HID's, DP Tunr 80econo, banks cooler, adreniline, msd dpi, optima's, autometers, more to come?
1BADTON is offline
post #5 of 22 Old 03-07-2013, 09:33 PM Thread Starter
jse51599's Avatar
No, I haven't, but I'm thinking of replacing them anyway. Also, I'd replace the trans mounts, u-joints, up-pipes, and who knows what else.... or sell as is then save for something newer??? Just sucks having more time to think than money to spend......
Jim
jse51599 is offline
post #6 of 22 Old 03-13-2013, 09:34 AM
Any sort of mistorquing may cause a cracked housing, also improper alignment to the block or overtightening of bellhousing bolts.
Owner/Founder of Georgia Diesel Power.
Current Sponsors: QuickTricks Automotive, Ray Paul Powdercoating, Ace Transmission, SoCalTrucks.com
Current Member Count: 16
TheRobenator is offline
post #7 of 22 Old 03-13-2013, 11:49 AM Thread Starter
jse51599's Avatar
Re: Transmission case is cracked
Yeah, I'm going to replace the trans mount and u-joints etc....
Jim
jse51599 is offline
post #8 of 22 Old 03-14-2013, 10:40 PM
Mine was cracked 180 degrees around the top half of the bellhousing. I couldnt find any reason why and threw a new one in along with flex plate, torque convertor and mounts. Its been a few months now and no problems yet.
Greenman01 is offline
post #9 of 22 Old 03-14-2013, 10:46 PM Thread Starter
jse51599's Avatar
Did you get your flex plate checked to see if it was bad?
Jim
jse51599 is offline
post #10 of 22 Old 03-14-2013, 11:22 PM
A bunch of teeth were missing. Probably should've checked for cracks as well...
