no shift p0705
i have a 2000 f350 7.3 with 4R100. soon after i bought it the tranny was staying in second gear all the time, with some talking to brian at BTS i found the alternator to be bad. so i got a new alternator and everything was fine.... drove it for a day or so with no issues then all of a sudden it takes off in second gear and i know if it does that it wont do the 2-3 shift. i put a scanner on it and i get p0705. i got a brand new oem ford trs and put it in cleared the code and same problem. now with searching around here i have found that this code is normally a wiring problem. i have looked over all the plugs and i dont see any issues. I now have the entire transmission harness out of the truck to look over all the plugs and i still dont see the problem! where is the normal "problem area" with the wiring in this truck? please heeeeelp
