auto to manual swap - Ford Powerstroke Diesel Forum
Old 01-28-2013, 02:36 PM
auto to manual swap
i have a 99 psd with auto tranny and i am wanting to swap it for a manual, its 4x4 with manual transfer case, I am just in the planning stage here looking for anybody wanting to go the other direction and wanting to swap parts my tranny works perfect has about 15k on rebuild stage 2 shift kit shifts pretty firm tansfer works perfect, so anybody out there interested? im located in southern indiana a few things have to check out before i do it, so at this point just trying to find somebody wanting to do manual to auto, or possibly some help on doing the swap someone wanting my parts or knows of anybody who has the stuff i need thanks
Old 02-06-2013, 06:53 AM
If you have an early 99 I have a manual PCM for you. I also have experience doing a swap. Located near Cincinnati Ohio if your looking for help or info.
Old 02-06-2013, 02:54 PM
I no everybody out there knows exactly what model of truck they have, but idk if mines an early or late 99 how do i tell? and how much u wanting
Old 02-07-2013, 05:01 AM
I don't really know for sure what the dates are but you should be able to check out the build date. There are also several differences such as the intake size and intake air heater not being there on the early ones.
The best way to see if my computer will work for your truck is probably to pull yours out to check the numbers on it and see how they compare with the numbers on mine. We can talk price once we figure out if we think it will work.
Old 02-07-2013, 05:09 AM
Send a message via Yahoo to wvrrcarknocker
Super Duty Trucks, LLC These guys can help with info and would probably buy your old parts and they aren't too far from you.
Old 02-07-2013, 04:32 PM
"diesel v8" badge on fender = E99
"diesel v8" on door = L99
Old 02-08-2013, 03:21 PM
my tags are on the door so its a late 99?
Old 02-08-2013, 03:25 PM
also, i am wanting to know exactly what has to be done with the wiring the guy that will be helping me said i should find that out before i start since he cant reflash the computer, will a chip set up for a manual clear it up? he said it would throw all kinds of codes as soon as its unplugged
Old 02-08-2013, 03:32 PM
aaand is the zf6 off a 6.8 gas the same as the zf6 put on the diesel? like mounting and are the gears in the diesel more beefed up than was put on the gas?
Old 02-08-2013, 04:25 PM
I ran mine with the automatic computer for a bit and it didn't actually throw a light. The only problem it had was some slight stuttering at certain loads. There is a pair of wires you need to cross to make it start. I don't think a chip will fix the problem.
I also don't believe the bell housings are the same between the gas and diesel. I think you need one from a 7.3.
