TRANS SHIFTING ISSUE AFTER CONVERTER INSTALL
Hey had the typical rattling torque converter on my 99 7.3 stock trans... 70k miles.. Im running an edge evolution tuner and a bd pressure lock as recommended years back....it does lock the converter in 3rd. My issue now after installing a multi disk converter on my first trip pulling my fifth wheel I would kick the OD off like normal entering the grade and typically it would run the grades great in 3rd gear lock up at any throttle setting... But strangly now it will while in 3gear hunt like go in and out of lockup acting almost like a downshift up and down to the point where I have to slow and put it into 2nd gear.... I simply slide a new converter on and refilled with new fluid... Nothing else changed!!! Stock trans... Same programmer.... For now I disconnected the bd pressure loc now there's no lock up at all....
Gotcha. But the TC you installed isn't OEM, right? What kind of TC is it exactly?
Mercon V I have been running that for quit a few years since it was recommended by a trans shop when my old converter was shuddering going into 4th gear lock up... After that I got the tuner which seemed to dial in the lock up problem...
Here's the deal about MERCON V & the early 4R100s: MERCON V was recommended in all transmissions, via a Ford Bulletin back in 2006. The big thing they didn't take into account is the lighter-duty coaster drum most early 4R100s & all E4ODs have. I'll bet if you upgraded the coaster drum/assembly to the heavier-duty units found in '01-'03 4R100s, you wouldn't have a problem with the new TC. The TC will give you slightly higher line pressure than a completely stock TC will have. It'll change the characteristics of the transmission & it's performance. The thing that sucks about this is, the coaster's cheap(about $90), but if you can't take the trans out yourself, it'll have to go to a trans shop.
