Possibly over reacting/wierd shifts
Hey fellas i had my transmission rebuilt about 6000 miles ago and just the other day while washing my truck i accidentally got the temperature sender wet. On my way home my autometer read 180 degrees which is way high since ambient was like -5 so i got home investigated and low and behold the connector was wet. after drying and reinstalling temp dropped instantly to 101. so since that almost heart attack i have been watching transmission like a hawk i noticed today while cruising at 40 mph at about 1300 rpm i went to roll into throttle and my tranny instead of downshifting just bogged down and slowly accelerated until i applied 3/4 or more throttle then it down shifted it felt like it was hanging. so i get on interstate and was cruising at 60 when i let off throttle to exit my tq didn't disengage till i had slowed by at least 15-20 mph. other than that the fluid still looks new smells new ect. am i just over reacting after the (wet transmission sender ordeal) or are these occurrences not right. i have a tendency to over react to small things especially when it comes to my truck.(every noise is a catastrophic failure)
thanks 2002 f350 172k miles 7.3 |
As far as the condition, don't go by what you see on the dipstick. Drain a small amount into a clean, light-colored container. That'll tell you a better story. |
Well, I haven't got a trans temp gauge yet. My truck is basically stock, but I know my tranny does the exact same thing. It takes about 5-6 seconds for my truck to respond to any throttle. Then like you said, it doesn't want to downshift. I also have a annoying vibration/grinding noise that I can't find. I had a massive issue with my 4x4 to where I needed up pulling axle shafts and driveshaft and running it 2 wheel drive. I am hoping and praying that my grinding and hesitation problems are not indicative of my tranny about to cark it!
And I know what you mean about any little noise! This truck is my baby and I freak every time I hear/feel something new! |
Tell me what exactly your trans is doing. Is it the exact same as the OP's, or do you have any other issues? |
Well, I'm not sure about temp, but basically it's the same problems. Although this morning on the way to school, it acted more to the normal side, but still a bit of lag. It also wants to shift late then when it does, wham! I thought this was normal because dads e4od does the same, just not as hard. It shifts at around 3000 rpms. I admittedly, have not changed the trans fluid in 20,000 miles. When I got the truck in April, while waiting on the bank, the owner had problems with the torque converter and had it replaced. He supposedly had the fluids throughout the truck replaced. He was pretty up front and honest about everything so I believe that he did. I've had so many problems with 4x4 that the tranny has been back burner
Right, no tuner yet.too many problems that takes all my money..... Plus I'm a college student.... Lol. I'll drain the tranny tonight when I get out of the woods. I appreciate the help!
Would that also cause a vibration?
Does just draining the tranny fix it or is there some other process?
Oh, and I pulled the axles out of the front so the u joints are out of the truck.
