No GEARS!!!!! PLEASE HELP before i go broke. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-01-2013, 01:55 AM Thread Starter
StrokeThis 7.3's Avatar
Question No GEARS!!!!! PLEASE HELP before i go broke.
Lets start by saying I drive a 2000 7.3 Powerstroke. Last night I parked the truck like normally and went to bed, the next day when I went out to leave and go to work I started the truck and let it run for 10 mins like always. Once it was warmed up I went to back out of the driveway..... NO REVERSE. Then i attempted to drive around the yard, put it in D and NO GEARS what so ever. Never had an issue with the trans what so ever. A few hard shifts when running on the race ready tune for my DP chip but not enough to do harm.
I need some help or ideas before I do a complete overhaul of the 4R100 trans
StrokeThis 7.3 is offline
post #2 of 13 Old 01-01-2013, 02:51 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Take the chip out and see what happens.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 13 Old 01-04-2013, 02:26 AM
700xxmaniac's Avatar
Look a ur fluid level.. If its low it will not
Move. If that don't help drop the pan
And make sure the filter didn't fall out, that happened to my friends obs once.
Sent from my iPhone using AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #4 of 13 Old 01-04-2013, 04:28 AM
jermcd's Avatar
not enough to do harm?... id have to argue with that.
currently driving a 335i bmw, no more powerstoke
Previous powerstrokes-
2002- F250 XL 7.3 auto, 4x4
2001- F250 Lariat 7.3 auto, 4x4
2002- F350 Lariat 7.3 Dually, auto, 4x4. 141k miles
jermcd is offline
post #5 of 13 Old 01-07-2013, 01:33 AM Thread Starter
Took the chip out still nothing, going to do a complete trans flush and new filter and gasket. See if that works.
post #6 of 13 Old 01-07-2013, 01:34 AM Thread Starter
Yeah i know jermcd, any hard shift isn't good at all.
post #7 of 13 Old 01-18-2013, 07:07 PM
Check you shifter linkage.
2000 F250
ZF6
EBV Delete
DieselRX glow plugs
Zoodad
Muffler Delete
Rancho shocks
6637 Mod with riffraff cover
Riffraff billet compressor wheel
Rishsd is offline
post #8 of 13 Old 01-18-2013, 07:51 PM
Quoted: 19 Post(s)
It's been a couple of weeks. Anything new on this?
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #9 of 13 Old 01-19-2013, 01:19 PM
RadarRider's Avatar
I'm having the same exact problem & I'm 99.9% positive I know what your problem is: The boost valve in your tranny's pump is stuck. Also: Check the valves in your accumulators located on the bottom-front of the transmission just behind where your filter mounts. What's happening is there's some gunk in the boost valve causing it to stick open & it's not cycling oil to your R, D, etc.
If you have any trans experience, it's an intermediate skill level job & you'll have to take the transmission out. Otherwise, it's gonna have to go to a good transmission shop & I'm not exactly sure how much a job like that will cost. Let me know if you want me to go through the steps or if you choose the latter. Either way, while the trans is out, I'd recommend looking at some tranny upgrades & you'll be golden.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #10 of 13 Old 01-19-2013, 01:21 PM
7thrizzy's Avatar
Re: No GEARS!!!!! PLEASE HELP before i go broke.
Check out the range selector! May be fried.....its hangin off the side of the transmision, black little box with wires ran into it
Sent from my SGH-T679 using AutoGuide.Com Free App
7thrizzy is offline
