Trans is slipping, I need HELP. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-25-2012, 07:16 PM Thread Starter
I have a 99 f250 7.3 with 95k miles. Just yesterday the trans started slipping. The thing that gets me is the trans only slips once in a while. It doesn't matter if the trans is hot or cold the slippage seems intermit ant. Sometimes I can leave a light and the truck takes off fine, the next light the truck will stay in one spot, in drive, and the rpm's will shoot threw the roof as I try to take off.
It's got me confused, why would the trans slip sometimes and not other times? Torque convertor?, trans itsel?
All fluids and filters were just recently changed by ford.
Any advice is greatly appreciated.
D555F is offline
post #2 of 12 Old 12-25-2012, 07:28 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Was it slipping before it was serviced?
dhanna6powerstroke is offline
post #3 of 12 Old 12-25-2012, 07:34 PM Thread Starter
That's hard to say. I just bought the truck off a friend. He got the truck completely serviced. I have the receipt. He said he never had a problem with any slippage. I registered the truck yesterday and the trans is slipping.
Were both just trying to figure out what it could be....
D555F is offline
post #4 of 12 Old 12-25-2012, 07:41 PM
Mod Newbie
Quoted: 19 Post(s)
If they replaced the filter, it's possible it's not seated properly, filter is cracked or they didn't pull the old seal out before installing new filter. If it's sucking air, that will cause a slip. Is the O/D light flashing?
post #5 of 12 Old 12-25-2012, 07:46 PM Thread Starter
They did replace the filter. With new fluid. I will check the filter tommorow. Would that cause the trans to slip at random times? It's got me confused because it only does it when it wants to. Any other ideas of what you think it sounds like? One mechanic said the torque convertor could be going?
D555F is offline
post #6 of 12 Old 12-25-2012, 07:47 PM Thread Starter
O/D Light is not flashing that I saw.
D555F is offline
post #7 of 12 Old 12-25-2012, 07:50 PM
Mod Newbie
Quoted: 19 Post(s)
I'd be taking it back in where it was serviced and tell them that it started after it was done.
post #8 of 12 Old 12-25-2012, 08:00 PM Thread Starter
The service was done one dec 2. The truck was driven and drove fine up until yesterday. I drove the truck to upstate NY and back to jersey and was fine. It came out of no where
D555F is offline
post #9 of 12 Old 12-25-2012, 08:12 PM
Mod Newbie
Quoted: 19 Post(s)
That would have been nice info to include from the beginning.
post #10 of 12 Old 12-25-2012, 08:23 PM Thread Starter
Regardless of what I said in the first post. The trans is slipping. I just included it was serviced recently. I just don't no what to check first. Maybe changing the filter will help?
D555F is offline
