Slop in stick zf6 - Ford Powerstroke Diesel Forum
Old 11-26-2012, 06:46 PM
Slop in stick zf6
I just bought a 99 f350 with zf6 and when in gear the stick can move in about a 4in diameter oval. Is this normal, if not how do I go about fixing it. Thanks
Old 11-26-2012, 06:48 PM
Subscribed my 06 with zf6 does the same thing I wanna fix it.
Sent from my iPhone using AutoGuide.com App
Old 11-26-2012, 07:17 PM
spool up that turbo!!
It could be in the shift tower or in the shift rails them selves more then likely the bushings in the tower are shot but any zf6 is gonna have a little slop
Old 11-27-2012, 08:41 AM
Yeah I popped the tower off and looked the other day and te bushing you speak of are the plastic ones that it actually pivots on right?
Old 11-27-2012, 12:51 PM
Yea it should be two pieces that the ball sits in
Old 11-27-2012, 12:58 PM
My tranny was supposedly recently replaced (I believe it) and I have less than 1.5" of play while its in any given gear.
Old 11-27-2012, 02:08 PM
Yeah they looks good but I think it's in the rails cause I do have difficult shifts in all gears not enough to say get a rebuilt but not as smooth as I believe it should shift.
Old 11-27-2012, 02:56 PM
Was the flat piece at the end of the shifter warn in at all? And believe or not the the more worn these transmissions are (within reason) the smoother they shift brand new they are pretty stiff and can be a pain sometimes
Old 11-27-2012, 03:27 PM
You mean the portion that actual contacts the shift selector the ball end looked like it had a bit of wear but not to severe where you can feel it. I've been leaning towards the clutch being smoked. I replaced the hydraulics and fluid already.
Old 11-27-2012, 04:40 PM
That is also possible
