transmission drain plug leak - Ford Powerstroke Diesel Forum
Old 10-25-2007, 04:06 PM
anyone know where i can get a new transmission drain plug? i changed my fluid and its leaking around it. ive loosened it, snugged it up, everywich way, still leaking though. any help is appreciated. thanks
Old 10-26-2007, 04:27 AM
Gun Nut
The dealer I'm sure - although it's probably a $500 part.
Does the washer around it look screwed up at all?
Old 10-26-2007, 04:53 AM
duct tape & zip ties
I would go to a hardware store. They usually have the copper washers. That is what usually seals the drain plug. Most likely that is all you need to replace.
