Sometimes wont shift pass second - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-16-2012, 05:30 PM Thread Starter
WHT00EX's Avatar
I have a 2000 Excursion. Has a 4r100 with a shift kit as well as a dp chip and mods listed in my sig. Recently it will randomly only have 1st and 2nd gear. It has a code P0750 (shift solenoid A) I know solenoid packs a are a common problem, but dont want to spend the money on one If i dont need it. It just bothers me because it doesnt always do it. When it runs through all the gears it has nice firm shifts. Then all of the sudden it will only have first and second. I removed the trans harness and tested all of the wires with my meter and found no problems. Any suggestions on other parts to test or how to test the solenoid pack without removing it? Thanks
SUPER DUTY SPRINGS
33'S
GAUGES
AIH DELETE
6637 AIR FILTER
CCV MOD
DP TUNER F5
SWAMPS 175/146 SINGLE SHOTS
4" EXHAUST
CLEAR HEADLIGHTS
WHT00EX is offline
post #2 of 3 Old 08-16-2012, 05:31 PM Thread Starter
WHT00EX's Avatar
Oh yea it is no longer 4 linked on the 44's and 2.5 tons. It is now on stock superduty springs with stock axles and 33's
SUPER DUTY SPRINGS
33'S
GAUGES
AIH DELETE
6637 AIR FILTER
CCV MOD
DP TUNER F5
4" EXHAUST
CLEAR HEADLIGHTS
WHT00EX is offline
post #3 of 3 Old 08-17-2012, 09:35 AM
I'd suggest sticking the solenoid pack in there, that is probably your problem, the solenoid is probably sticking or going out. If it continues to do it, take it apart and look at the clutch packs. reverse and 4th gear drum like to go out in those too.,
Owner/Founder of Georgia Diesel Power.
Current Sponsors: QuickTricks Automotive, Ray Paul Powdercoating, Ace Transmission, SoCalTrucks.com
Current Member Count: 16
TheRobenator is offline
