2002 4r100 wont shift past second. stuck valve ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-07-2012, 08:33 AM Thread Starter
I'm trying to help my brother in law out. His 2002 f250,7.3, stopped shifting past second suddenly last week. This truck is low mileage and has no chips/programs/mods. It shifts fine foward and reverse, starts off in first then shifts smoothly into second. NO 3rd or OD. Trans temps are good and fluid looks fine.
After searching the forums I'm seeing that it looks like a stuck solenoid or stuck valve. Any advice on this before i drop the pan, like the location of the valve it might be. I'm very mechanicaly inclined, just not familiar with these transmissions.
Thanks a bunch for any advice,
Randy
Fence-one f250 is offline
post #2 of 7 Old 05-07-2012, 09:35 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Valve body is right up above the pan and filter. very easy and there's a write up here in the tech files on it.
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 7 Old 05-09-2012, 04:46 PM
Codum's Avatar
I had the same thing happen at 407k. Fluid pink, shifted fine to 2nd. 3rd and OD went from occasionally to nothing over couple days. I was told by the expert John Wood my center section went out. He said it was a design flow that he has seen happen from 20k miles to 400k miles like mine. He's a super nice guy, he picked up the phone the first time I called. Good luck.
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #4 of 7 Old 05-20-2012, 06:31 PM
Guns & Powerstroke's
HillClimber350's Avatar
Not to hijack but what did it take to fix? Mine is showing similar issues.
2001 F-250 Platinum Edition
BTS Trans, 6.0L Cooler, DP Tuner, AFE Stage 2 Intake, 4" turbo back, Bean's 1.0 housing, A/C mod, Billet T-Stat Housing with 203* T-Stat
HillClimber350 is offline
post #5 of 7 Old 05-22-2012, 05:14 PM
Codum's Avatar
Had to be rebuilt, I went with a ford remain for the 3 year unlimited mile warranty.
DIY 6637
Warn Premium Hubs
"We Farm for Ducks"
Stock 225k miles
Codum is offline
post #6 of 7 Old 06-25-2012, 12:48 PM Thread Starter
Stuck 2/3 valve
For anyone that may like to know, it was a stuck 2/3 shift valve. Bought one online that has a little bit more clearence and that fixed it. Since then I've helped fix 2 others that the trans shop said "HAD" to be rebuilt. If your trans is low mileage, check this first...
post #7 of 7 Old 08-09-2013, 05:12 PM
I know its been awhile but having a 2-3 shift problem pulled the valve body out and found one that is sticking but not sure how to remove the valve
pfd934 is offline
