o/d off light blinking and no speedo when trailering - Ford Powerstroke Diesel Forum
Old 04-10-2012, 01:39 PM
I have a 99 F-350 crew cab dually 2wd 7.3. When i go to tow my trailer, o/d off light blinks and speedo does not work. I have had this happen on two different trailers. when unhooked from trailer everything is fine. Have tried with o/d off and on does it either way. Speed sensor in rear has been changed, torque converter has been changed to a billet one with a 300 rpm lower stall and still same problem. HELP PLEASE prostang@optonline.net
Old 04-10-2012, 07:22 PM
Had same problem, i disconnected the trailer breaks under the dash and replaced the stop/hazard fuse that blew. Hasn't done it since......have no clue why it happened
Old 04-11-2012, 04:37 AM
Will try that. Thanks.
Old 04-11-2012, 04:39 AM
Sounds like you just masked the problem.
Personally, I'd fix it and check all your trailer wiring as well as your brake controller's.
Old 04-11-2012, 06:01 AM
Have checked trailer on another truck and no problems. Checked all connections on brake controller all good. Have been told to check gem module on back of fuse panel. So that's next
Old 04-11-2012, 09:38 AM
I mean the wiring on your truck
My Samsung SGH-I997 made me send this.
Old 04-11-2012, 10:31 AM
Truck factory wired
