ZF6 Noise
My ZF6 has got a bad clutch chatter when the clutch is out and trans is in neutral. When I press the clutch the noise stops. It will also stop when I rev the engine up in neutral. When the truck is in gear is doesn't make any noise. I begining to think I need to change my transmission fluid. What do you guys recommend to help with the clutch chatter.
FYI I'm running a Valair HD Organic Kit. Luke |
With the clutch pedal out (meaning you're not pushing on it), any noise you hear wouldn't be from the clutch itself unless it's fallen apart. The only relative motion with the clutch pedal out would be in the transmission itself.
