4R100 transmission viberation/shudder - Ford Powerstroke Diesel Forum
Old 02-19-2012, 08:06 PM
I just installed the transmission I rebuilt when I took it for a test it sifted great through all gears. When I let off the throttle the truck begain to sudder/viberate viggerusly. The rebuild included a rebuilt toque converter, the transgo tugger kit and the Alto performance steels and cluch plates. The pump was rebuilt by a reputable transmission shop. Anyone have any idea what my be casing this.
Chris
Old 04-01-2012, 09:07 AM
Any luck im having same issue after rebuild and new torque conerter
Old 04-05-2012, 08:03 AM
Have you checked ur driveshaft carrier bearing or ujoints?
Old 12-02-2012, 06:08 PM
Those tugger kits seem like if something just not perfect it will mess up reverse, creating a shudder and almost no backing up ability. Im having that problem right now after a rebuild
Old 12-02-2012, 06:20 PM
If the only thing was the trans that got done, take it back.
I don't understand why ppl install "kits" like that when you could install a professionally done valve body
I made my Samsung SGH-I997 send this.
Old 12-02-2012, 06:25 PM
cuase the kits are nice if done properly and half the cost
Old 12-03-2012, 01:51 AM
I had my transmission rebuilt also in a 2000 f250 and it shifts a little firmer and I had shuddering problems also when I let off the pedal and I found it to be the rear u-joint, I was worried the problem was in the transmission, but it wasn't.
Sent from my Autoguide iPad app
